LTB 96-99 Celica Manual hatchback gt |
Apr 11, 2018 - 9:03 PM |
Enthusiast Joined Sep 20, '11 From Florida Currently Offline Reputation: 11 (100%) |
I have been having issues with my current 99 gt hatchback. I cannot for the life of the car figure out what is causing it to misfire. now I'm thinking my next option is instead of buying and replacing every switch valve and sensor, to just buy another hatch and swap the parts over. Another diagnostic approach would be to take a day to just swap every part over (one at a time) from the new car to my current one and individually test it to get to the bottom of this.
I have replaced Egr valve Egr solenoid Egr vavumme switch Egr diaphragm (behind intake manifold) Spark plugs Wires Distributor, rotor, and cap Pvc valve Alternator Battery Fuel pump Engine temp sensor Thermostat And ecu |
Apr 12, 2018 - 9:12 AM |
Enthusiast Joined May 2, '15 From NY Currently Offline Reputation: 3 (100%) |
Have you tested the coil and ignitor? 96+ has the coil and igniter placed outside of the distributor, and those should be one of the first parts to check in case of misfire.
You could, and should have easily tested most of the components you listed rather than replacing them. Besides, "new" components aren't always working components, especially if you went with aftermarket parts. |
Apr 13, 2018 - 10:57 PM |
I don't know how to properly test. Maybe someone in Orlando Florida can help me?
Apr 13, 2018 - 11:09 PM |
You can usually buy the shop manual off eBay for $50 or less, in depth and extensive testing for every component on the car.
Apr 13, 2018 - 11:18 PM |
Maybe I'm just frustrated and don't want to do it alone
Apr 14, 2018 - 6:30 PM |
Enthusiast Joined Jun 2, '16 From Toronto, ON Currently Offline Reputation: 0 (0%) |
do you have a 5SFE engine? i was having problems with my car idling and doing what they did in this video fixed it. https://www.youtube.com/watch?v=WsP2-HKz7vE it took around 20 minutes and cost around 10$
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:27 AM |
