> Buying a Celica tips?
post Apr 23, 2018 - 7:42 AM
KeithL
Joined Apr 23, '18
From Dublin Ireland
Hi all, I'm going to view a 94 st202 2.0 this weekend. I'm new to celicas is there any common issues to look out for?
It's been sitting up for 8 years. So a full service and new fuel would be a good starting point. Anything else before I started it up?
Also inside is a bit damp, do they have any common issues as far as leaking into the cabin?
post Apr 23, 2018 - 10:43 AM
cheela
Joined Feb 2, '07
From Berlin, WI
8 years is a long time. was it sitting outside or garaged? that will make the biggest difference.
but some things to look at would be all the rubber, hoses, seals etc. check for cracks and brittleness. check the radiator, if it looks brown or discolored, it's on it's way out.
take a look at the bottoms of the doors and the hatch for rust. the rear quarter panel behind the tire. if it has a sunroof, check and make sure it's not leaking and the drain plugs aren't clogged.
other than that, yes a full service. drain and replace all fluids and see how well it runs after that.
post Apr 23, 2018 - 3:00 PM
Buy another one. Unless you plan on sinking money and long wrenching hours, buy one that runs now. All cars ran before they were parked....
post Apr 23, 2018 - 4:21 PM
Box
Joined Feb 23, '12
From Warrior, AL
If it was garaged and moved around occasionally it'll be fine, so finding out how and where it was sitting would determine rather or not it should be gotten. Also why, sometimes cars get parked and the car is perfectly fine when it happens due to various life stuff. Either way new tires and fluids is a given, also struts. Possibly brakes. If it runs out ok just be ready to replace all wear and tear items right off the bat. Even then unless it's a model and colour combo you're just dying to get it there might be better options out there.
Oh 3rd gear synchro likes to grind on downshifts is a common problem, so that. Outside of that it's usual old used car stuff.
2001 Miata LS 5-speed
post Apr 24, 2018 - 2:34 PM
And all box put threre sounded like bunch of money and wrenching hours
post Apr 24, 2018 - 5:57 PM
Box
Joined Feb 23, '12
From Warrior, AL
It is, but it's worth it if it's exactly what you're wanting in one. Being they've just come across the Celica in general I doubt it though. Unless it can be gotten for 25%+ less, all parts needed to get it 100% sound again included, than a comparable car needing nothing I'd say pass.
post Apr 25, 2018 - 6:15 PM
I rather buy one that i can ejoy now
post Apr 25, 2018 - 10:15 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (njccmd2002 @ Apr 25, 2018 - 6:15 PM) *
Yeah but my Firebird is a prime example of why sometimes it's worth it, as it sat for 6 years while the owner was in Japan. It was the first like it that I've ever seen come up for sale locally, and I think I've seen one other like it up for sale nationally in the three years or so I was on and off looking at them. Though at least his father drove it from time to time so it kept things from seizing, but it still needed tires, fluids, and shocks. Which honestly are things I'd replace on any used car anyway unless they were recently replaced with what I'd use, which I doubt since most people throw on the cheapest stuff before selling a car.
post Apr 26, 2018 - 9:48 AM
ST204GT83
Joined Mar 6, '17
From Sacramento
Make sure all the fluids are full.
post Apr 26, 2018 - 11:17 AM
QUOTE (Box @ Apr 25, 2018 - 10:15 PM) *
Box will be available for wrenching time.
In all seriousness,since you never posted again. What did you end up deciding?
Lo-Fi Version Time is now: April 22nd, 2025 - 7:20 AM
