You got it, ST204 axles are interchangeable with SS-III axles. It’s still an S54 in the same chassis so everything goes together perfectly. I’ve had an S54-06D since like 2011 and I think I’ve only used one SS-III specific axle, and the boot ripped shortly after so it was back to USDM GT axles.
Enthusiast ![]() ![]() Joined May 2, '15 From NY Currently Offline Reputation: 3 (100%) ![]() |
S51-S54 "inner" axles are all same, LSD or not. It's the E153 where LSD axles are different. Plenty of people have put in factory LSD axles into S-series boxes without issues.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
your axles will be fine, and ill confirm the MR2 E153 is not drop in, it needs modification because the linkage is on the wrong side. you want an E153 from a Solara.
but since you got the BEAMS trans its all moot -------------------- 2001 Celica GT-S Turbo
Lo-Fi Version | Time is now: August 19th, 2024 - 2:28 AM |
