Power, Breaking/blower motor |
Apr 26, 2018 - 9:45 AM |
Enthusiast Joined Mar 6, '17 From Sacramento Currently Offline Reputation: 0 (0%) |
When im in traffic, foot on break pedal and air is going(not ac, just the fan) usually on 2 or 3, it sucks a lot of power from the engine and my rpms drop down. Battery is somewhat new and alternator is brand new. Is there any way to change that? I think I had this same problem with my ST back in the day.
Apr 26, 2018 - 11:20 AM |
Put the a/c on so your rpms drop for a good reason...
Your ac compressor clutch could be stuck -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Apr 26, 2018 - 12:50 PM |
Questionable grounds?
'93 MX-5 LE |
Apr 26, 2018 - 5:14 PM |
Put the a/c on so your rpms drop for a good reason... Your ac compressor clutch could be stuck It's not a huge drop, just a little, same thing at night when headlights are on, foot on break, or when I turn on my fog lights, which are 100 volts, so that's understable. |
Apr 26, 2018 - 5:29 PM |
Have you had both the new battery and alternator tested? There could be a slight defect in either one, otherwise I’d agree that it’s likely a ground issue.
Apr 26, 2018 - 7:32 PM |
Thanks guys.
Apr 26, 2018 - 10:16 PM |
My idle is fine with the blower on, but does dip somewhat when the amp is running and I hold the brake. It does have a new alt and battery, to add to the discussion like Dan said, so I suspect grounds for myself as well.
'93 MX-5 LE |
Lo-Fi Version | Time is now: November 24th, 2024 - 6:14 AM |
