> GT four front brake conversion question
post May 30, 2018 - 9:26 PM
95chameleonGT
Joined Aug 4, '17
From Hagerstown
What size hub centric ring do you have to use to center the brake rotors on the stock hubs? I'm using brz rotors and I tried doing the measurements myself but the first set I ordered didn't fit.
post May 31, 2018 - 8:06 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
You'd need to collect get the rotors bore size and the hubs bore size measurements. Be aware that the hub may have a chamfer at the base of the bore circle making it slightly larger than the listed bore size.
Measure again and get a couple more made
エキサイティングカーレーシングチーム!
Lo-Fi Version Time is now: February 18th, 2025 - 2:45 AM
