Car keeps over heating help |
Jun 6, 2018 - 7:12 AM |
Enthusiast Joined Jan 27, '14 From Houston Currently Offline Reputation: 0 (0%) |
Both fans work.
Car warms up to normal quickly 5 mins top. Water pump and thermostat swapped 15k miles ago bad things I’ve noticed Dirty radiator almost brown liquid due to oxidation original radiator I believe And been working in really dirty environments radiator has bugs, dirt, feathers on fins What would y’all suggest to fix this.? Car only over heats when it’s super hot and on the highway with AC on Goes back to normal if I turn of ac Car stays in normal temp in city with AC on or on idle for long period time |
Jun 6, 2018 - 1:09 PM |
Enthusiast Joined May 2, '15 From NY Currently Offline Reputation: 3 (100%) |
Based on the symptoms, I would say the radiator sure isn't helping the situation. Keep in mind that the radiator has the smallest passages in the system, and it effectively acts as a filter trapping any debris and crumbs, reducing it's efficiency over time.
As for the fins, are you sure you're talking about the radiator and not the AC condenser? AC condenser sits in front of the radiator. Messed up fins and blocked passages would also reduce the system efficiency, blocking airflow to the radiator. They do sell rad fin straightening tools, so might be worthwhile to clean things the best you can and straighten fins out. Finally, the coolant itself. Was it changed when the thermostat was replaced? It doesn't last forever, either. Toyota says 6y I believe, I'd say 10 years is tops for the coolant. If I were you, I'd throw new rad on it and flush the coolant with Toyota Red (1 gal of concentrate + 1 gal of distilled water is what you need). The plastic tops on the rads crack with time, so rad is almost a maintenance item on these chassis. |
Jun 6, 2018 - 5:17 PM |
Based on the symptoms, I would say the radiator sure isn't helping the situation. Keep in mind that the radiator has the smallest passages in the system, and it effectively acts as a filter trapping any debris and crumbs, reducing it's efficiency over time. As for the fins, are you sure you're talking about the radiator and not the AC condenser? AC condenser sits in front of the radiator. Messed up fins and blocked passages would also reduce the system efficiency, blocking airflow to the radiator. They do sell rad fin straightening tools, so might be worthwhile to clean things the best you can and straighten fins out. Finally, the coolant itself. Was it changed when the thermostat was replaced? It doesn't last forever, either. Toyota says 6y I believe, I'd say 10 years is tops for the coolant. If I were you, I'd throw new rad on it and flush the coolant with Toyota Red (1 gal of concentrate + 1 gal of distilled water is what you need). The plastic tops on the rads crack with time, so rad is almost a maintenance item on these chassis. Thanks for the update I’ll go head and order some stuff and go head and change them I’ll Let everyone know if the issue has been resolved thanks. |
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:34 AM |
