![]() Enthusiast ![]() ![]() Joined Jan 30, '14 From Cortland NY Currently Offline Reputation: 5 (100%) ![]() |
Hello fellow 6gc fam,
Been piecing together a RHD set up for a little while now... keyword little. If anyone has these parts that would save me some fabrication time and would rather go OEM anyways. Here's what I'm looking for: Firewall assembly, inside & outside (or if someone randomly has a front clip preferably) Under dash components - HVAC system, none of the venting but units mounted to the firewall Dash bar mount for the passenger side (left side) metal brackets for the bottom of the dash/panels located above the kick panels Have the rest of the set up, just looking for these odds and ends. If you are near by, which more thank likely not, let me know distance from 13045 and might just make a roadtrip out of it. Let me know, Thanks guys and gals. -------------------- 1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool. |
Enthusiast ![]() Joined Sep 5, '04 From Quebec, Canada Currently Offline Reputation: 0 (0%) ![]() |
i have pretty much everything but you would have to come get them in Quebec
i have pretty much everything but you would have to come get them in Quebec ![]() Extremely tempting, would you be willing to ship smaller bits at the moment? -------------------- 1997 ST:Limitedly Green
I feel like you might need more than what you think you do, i did the conversion on the other side and let me tell you there is a lot of parts that you will need. I also have the harness, all the plastics, the dash, etc.
The firewall though might not be int he best of shape to swap as it has been cut a couple of place around the edges. If you want to come by and buy everything, i will let you go with everything for very cheap. I see you are 6 hours from my place, it is a pretty good drive though. |
Lo-Fi Version | Time is now: April 20th, 2025 - 3:17 PM |
