5 Pages V  « < 2 3 4 5 >
> Safari Rally inspired build, tall and off road capable 6G - GT
post Nov 13, 2018 - 10:31 AM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
Thanks, I'm here to build dream cars for myself and anyone that cares to enjoy it...
So, Photobucket has decided to revamp their hosting of photos, apparently by adding in dynamic links, jerks.
post Nov 14, 2018 - 2:54 PM
cheela
Joined Feb 2, '07
From Berlin, WI
yeah, I stopped using photobucket after their first fiasco. I've been using flickr ever since.
post Nov 29, 2018 - 12:33 PM
Nial
Joined Aug 25, '08
From England
Dont know if it will ever come to pass, but i an working with a pal of mine to design and get 3d printed a safari rally type snorkel. I am sure if it works out he would sell you the design which you can then send off to a local 3d printers to get produced.?
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
post Nov 29, 2018 - 3:32 PM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
QUOTE (Nial @ Nov 29, 2018 - 1:33 PM) *
That would be fantastic. Funny, I never even considered designing a snorkel in a 3d cad program and then sending it out to be made. The original WRC design would be pretty cool, but the flex tubing seems like it could have been out a bit further to the outside, to take up less driver view out the windshield.
post Nov 29, 2018 - 4:21 PM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
https://s265.photobucket.com/user/jrally/71...iginal.jpg[/IMG
Another full failure with Photobucket's latest update...
Try it again...
https://beta.photobucket.com/u/jrally/p/71b...54c5a7ed87[/IMG
This post has been edited by Roodwerks: Nov 30, 2018 - 4:25 PM
post Nov 30, 2018 - 1:31 AM
Nial
Joined Aug 25, '08
From England
I guess the bonus of the flexi bit is that it will go more or less where you want, although being in the uk its on the passenger side for us so not really something i have considered.
post Dec 13, 2018 - 12:56 PM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
Will this work..? Guess not...
This post has been edited by Roodwerks: Dec 14, 2018 - 11:40 PM
post Jan 28, 2019 - 2:44 PM
GuYun14
Joined Apr 13, '16
From Milwaukee
Any updates?
post Feb 12, 2019 - 4:29 PM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
No pics, but you can find pictures of this project and a few others on my Instagram - roodwerks
I've mostly been trying to track down a rough running issue when it's warming up in colder weather. It runs fine at first start up, 1-2 minutes later it starts misfiring under acceleration, a few minutes after that, sometimes up to 15 minutes later it will start running fine..? It's a weird issue with NO CEL at all. It's been doing it for a few months.
I did buy and mount a new set of center LED flood lights on the front pod, about 3 times brighter than the first pair. I've also been gathering pieces to build a custom rear subframe and arms to fix the lifted geometry and make room for a possible future rear diff..
20181104_114447 by Jon Rood, on Flickr
20181104_114034 by Jon Rood, on Flickr
This post has been edited by Roodwerks: Feb 27, 2019 - 3:58 PM
post Feb 25, 2019 - 3:54 PM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
I finally figured out my poor running issue when cold, bad igniter. The engine pulls easily to 6K rpms now. Of course now the harmonic balancer had to de-bond and start coming apart. If it's not one thing it's another...
-Jon
post Feb 28, 2019 - 11:38 AM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
This past weekend, it was half off at the salvage yard I spend a lot of time shopping at. So, while grabbing parts, I scored a pair of rear speakers with the crazy large plastic brackets, a left-hand high beam housing plus a few other small items. While installing the speakers, I decided to go ahead and use a cheap hot-rodders trick, installed roofing repair adhesive tar tape on the inside of the panels. It's more about changing the sheet metal density then getting even coverage. The back of the car is a good bit less droney now. I've removed the back seat and don't have the cover in the rear luggage area obviously, so it had gotten a bit noisy.
RearSpkrs by Jon Rood, on Flickr
SoundsDdn1 by Jon Rood, on Flickr
SoundsDnd by Jon Rood, on Flickr
post Mar 1, 2019 - 11:52 PM
GuYun14
Joined Apr 13, '16
From Milwaukee
QUOTE (Roodwerks @ Feb 12, 2019 - 5:29 PM) *
That thing looks so beastly. How does it handle so far? Any rubbing/suspension issues?
post Mar 4, 2019 - 10:57 AM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
The handling is really pretty decent since I was able to retain the swaybar front and back. As for rubbing, yes, hard turns the front tires are contacting the back of the wheel well / firewall area. Under compression, the rear tires move back so far that they contact the backside of the body. It's not enough to worry about daily driving, but all issues will be corrected in the near future with custom rear suspension, probably cutting and moving the front wheel well further back into the cabin area.
post Mar 7, 2019 - 5:46 PM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
Now that I found a decent, free, photo host I will probably start sharing more progress. This past weekend I installed an "Oh-****" Handle, as you know, our cars didn't come with any passenger side grab handle.
Oh****Handle by Jon Rood, on Flickr
post Mar 8, 2019 - 10:54 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Did you bolt into the A-Pillar structure behind the trim, or is it just bolted into the trim itself?
~bloodMoney
post Mar 8, 2019 - 12:12 PM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
QUOTE (bloodMoney @ Mar 8, 2019 - 10:54 AM) *
I used one existing round hole (top one) and drilled the other to insert M8 rivet nuts. So they are bolted into the A-pillar, securely. I made the tool to install the rivet nuts, pretty simple set-up, but rivet nut tools usually aren't too pricey, I'm just cheap I guess.
post Mar 8, 2019 - 3:43 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Gotcha. I like that it's functional.
~bloodMoney
post Mar 20, 2019 - 4:30 PM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
I've replaced just about everything on the engine that could cause my now 2000rpm idle. I've replaced or checked every hose. The important sensors are new or reman; IAC, MAP, CTS, ATS, O2, etc.. Anyone else run across this with the age of our cars and possibly as high a mileage as I have, 280K..? The engine runs great, just a horribly high idle. Ggguuuuurrrrr.......
post Mar 21, 2019 - 8:32 AM
richee3
Joined Jun 29, '08
From Denver
Might be a dumb question but have you checked the throttle cable? It may need adjustment or it might have a slight burr on the cable. It’s been forever since I’ve had a 5S but I believe there’s an adjustment screw on the throttle body as well, although I think I remember that being addressed already.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 21, 2019 - 10:25 AM
Roodwerks
Joined May 2, '18
From Phoenix, AZ
QUOTE (richee3 @ Mar 21, 2019 - 9:32 AM) *
No dumb questions in my book. But, yes, the throttle cable is adjusted, if anyting, a bit too loose. The only adjustment screw is the butterfly stop screw, which is properly adjusted, the plate couldn't get any more closed.
Lo-Fi Version Time is now: April 21st, 2025 - 6:01 AM
