> 7AFE to 3SGE (non beams/turbo) Conversion, Is there anything that needs to be done to the loom?
post Aug 20, 2018 - 11:04 AM
Makarintosh
Joined Dec 23, '15
From Ireland
So I have a 3SGE with box, loom, shafts, ecu. Basically to do a straight swap into the 7AFE celica but curious to know if there is anything with the wiring i need to adjust. Trying to find details on it and its very hard to find anything. Any help would be appreciated.
As far as I can tell, its just dump straight in. I am aware of the engine mount being different, that's ok. Just the electrics I am more concerned about.
post Aug 27, 2018 - 8:35 PM
there are a few guys here that have done the swap and you can read in detail, there are a few changes in the loom, at the EA1 plug, and maybe clutch pedal.
Assuming you have rhd car, there should be no reason for you to extend harness
post Sep 16, 2018 - 2:07 AM
Makarintosh
Joined Dec 23, '15
From Ireland
Thanks for that smile.gif the swap was a success! Car runs on its own power.
I have a few minor problems which I can deal with fixing later but ATM the radiator fans kick in with accessories. Any thoughts as to why?
The harness around the engine hasn't been touched so kinda confused why it would just kick in. I'll see about relay and make sure fuses are OK but no idea what it could be.
post Sep 17, 2018 - 8:07 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
IIRC, if there is no signal from the temp sensor to the fans, they fail to the ON position. My GT4 was the same way due to a broken wire at the connector.
~bloodMoney
post Sep 17, 2018 - 5:23 PM
QUOTE (Makarintosh @ Sep 16, 2018 - 2:07 AM) *
What accessories, be more specific, I just went over my whole cooling system...
post Sep 26, 2018 - 7:02 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
if I remember correctly, the water temp sensor was backwards polarity to the 7A and 5S/3S in other words when one is open, the other is closed. and the computer gets confused.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 29, 2018 - 2:05 PM
Makarintosh
Joined Dec 23, '15
From Ireland
QUOTE (njccmd2002 @ Sep 17, 2018 - 6:23 PM) *
When I turn the key to Accessories position, before turning the starter over.
post Sep 29, 2018 - 2:08 PM
Makarintosh
Joined Dec 23, '15
From Ireland
QUOTE (Smaay @ Sep 26, 2018 - 8:02 PM) *
But all of the engine wiring and ECU is from the 3SGE. Unless its down to the engine bay wiring that connects the lights etc? is there another sensor that goes to the radiator along with the sensor water temp sensor under the throttle body?
Lo-Fi Version Time is now: February 16th, 2025 - 2:38 PM
