4 Pages V  « < 2 3 4
> NETS TOY
post Feb 13, 2019 - 1:15 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
QUOTE (bloodMoney @ Feb 13, 2019 - 7:30 AM) *
QUOTE (NgoFcukinWay @ Feb 13, 2019 - 2:26 AM) *
Bet you won't.
but if you do....I might have one for sale. lol
LMAO! Stacy would kill me if I bought another one right now...
Tell her you got it on sale. for an additional $100, i can provide a bill of sale that will match whatever price you tell her.
-Alex {](O_o)[}
post Feb 13, 2019 - 4:41 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
QUOTE (NgoFcukinWay @ Feb 13, 2019 - 2:15 PM) *
Bet you won't.
laugh.gif laugh.gif It could be free and she'd still kill me for bringing more junk home to take up space.
~bloodMoney
post Feb 14, 2019 - 12:09 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Careful, if she likes the car she might kick you out to make room for the car.
post Feb 20, 2019 - 10:30 AM
NetsToy
Joined Jul 5, '14
From Indianapolis, IN
QUOTE (richee3 @ Feb 8, 2019 - 9:32 AM) *
You’ll have to ask Chris at the Midwest Meet about how he found out 96+ seatbelts won’t click into 94-95 latches. laugh.gif
For your wheels, you’ll probably want spacers. 17x7 +40 will fit but will be near stock fitment. My Caldina wheels are 17x7 +45 (so 5mm more sunk in than your Konigs) and while they fit, they don’t look good at that offset. I’m running 15mm spacers to make the wheels effectively +30 and front fitment is okay, but rear should really have a 20-25 mm spacer for better fitment. I’m not after stance or flush fitment so I’ve left it, but you’ll see what I mean when you get the wheels mounted. Just a little bit more flush will make the car look a lot more aggressive.
John has taught me so much! The guy really knows his stuff. smile.gif And yes, he did mention that he used to be involved in the 6gc world.
What kind of spacers do you recommend? From my research, it seems like I should go with hub centric bolt on spacers. I have not yet looked into brand and quality yet.
QUOTE (NgoFcukinWay @ Feb 11, 2019 - 2:30 AM) *
She'll need spacers for that hella flush fitment. 10mm front and 15mm rear.
Annette, where'd you get the camber bolts from?
I'm confused. Shouldn't the front and back spacers be the same?! To get the factory flush fitment? My fenders are not rolled or anything.
I got Moog camber bolts from Rock Auto - the website said they were "performance" parts. And I know, I know, Ted said it was a waste of money, but I wanted to get real camber bolts so that I can hopefully understand how they work, by having the actual part, and putting it on myself. That's how you learn right?!
CAMBER BOLTS
QUOTE (cheela @ Feb 11, 2019 - 9:03 AM) *
You got the brakes, you got the coilovers, now you got the wheels. next logical step is an engine swap! wink.gif
Uh huh. Baby steps. Baby steps.
And somehow you've convinced me that this may eventually be a good idea.
Repetition and persistence work! Who knew!?
QUOTE (bloodMoney @ Feb 11, 2019 - 12:09 PM) *
Man, I miss my car.... Stalking project threads doesn't help either.
I'm sad I never got to see your Celica. Is there a build thread for it?
1999 - Toyota Celica GT Vert Black
1999 - Toyota Celica GT Vert Super White
post Feb 20, 2019 - 10:10 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (NetsToy @ Feb 20, 2019 - 10:30 AM) *
I personally just have 15mm Ichiba slip-on hubcentric spacers with extended studs, but I wouldn't go any bigger than 15mm slip-on spacers. Link to the spacers I have
Based on this, a 15mm spacer would put you about where you need to be.
QUOTE (WannabeGT4 @ Jan 10, 2006 - 11:02 PM) *
Ideal Offset in Relation to Wheel Width (standard ride height):
Width - Offset
7.0"-----30mm with 15mm spacer (effectively 15mm) *
7.5"-----31mm with 10mm spacer (effectively 21mm) *
8.0"-----33mm with 05mm spacer (effectively 28mm) *
8.5"-----35mm
9.0"-----42mm (probably too wide no matter what offset)
This will make the rim almost flush with the side of the body. These offsets and offset/spacer combos will prevent the "sucked in look" that the factory wheels have.
Ideal Offset in Relation to Wheel Width (lower ride height):
Width - Offset
7.0"-----36mm with 10mm spacer (effectively 26mm) *
7.5"-----33mm
8.0"-----40mm
8.5"-----46mm *
9.0"-----53mm (probably too wide no matter what offset)
The rim will sit just behind the fender. In order for the rims to tuck into the fender well on lowered cars the the rim must sit back into the wheel well by 11mm compared to the standard ride height offset recommendations.
* Clearance issues prevent the use of most rims with offsets lower than 30mm. The spacer will actually lower the offset and at the same time move the rim away from the offending components.
* 8.5" rims may or may not fit on lowered cars.
Offsets shown are positive.
Offset is measured from the wheels center line to the mounting surface.
Source
Ideally getting wheels that fit without spacers is best but we can't all get that lucky.
Per Alex's comment, we need a different offset in the rear to get flush fitment. For instance, my current fitment is 17x7 +30 which is close to flush but still slightly sunk up front, and noticeably sunk in the rear. I'd need another 5mm up front and another 10mm in the rear to have better fitment. This is the best picture I have to show how the rear looks more sunk than the front because of the identical offset.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 21, 2019 - 9:34 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Photobucket destroyed my build thread, so there's no real point to go back to it. Here's a quick storytime:
The Beginning:
The Pinnacle:
The End:
I hate BMWs.
This post has been edited by bloodMoney: Feb 21, 2019 - 9:35 AM
~bloodMoney
post May 31, 2022 - 2:51 PM
NetsToy
Joined Jul 5, '14
The Day My Heart Broke Into A Million Little Pieces
post Jul 2, 2022 - 2:18 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
the conv didnt look to bad. till you got to the other side. yikes
post Jul 12, 2022 - 1:11 PM
enderswift
Joined Jul 12, '08
oh no
that was such a clean car too
post Jul 12, 2022 - 3:28 PM
Bitter
Joined Mar 11, '06
Wait, what happened?
post Jan 31, 2023 - 12:10 AM
NetsToy
Joined Jul 5, '14
It's been a year and a half and I'm still sad about this. frown.gif She was my favorite little Celica.
We had a great 15 years together. She was just about to roll over 300k miles too!
RIP
post Aug 7, 2023 - 9:17 PM
Bitter
Joined Mar 11, '06
I've been seeing some nice clean 7th gens for sale, just sayin. You can come over to the dark side, we have cookies.
post Aug 17, 2023 - 9:55 AM
CoolZeen
Joined May 30, '16
From wild 100's, South Chicago
QUOTE (Bitter @ Aug 7, 2023 - 9:17 PM) *
I been thinking the same, for a daily , since I been hanging with the 7th gen crowd.
post Sep 5, 2023 - 5:06 PM
NetsToy
Joined Jul 5, '14
As tempting as the cookies are, LOL, I don't see myself in a 7gc. I like the convertibles too much.
If I ever drove something different, I think it'd be a new MX5, or maybe a Lexus SC or IS.
post Feb 3, 2024 - 9:31 PM
Bitter
Joined Mar 11, '06
Ok I know. MR2 Spyder. They're super fun.
post Feb 6, 2024 - 2:10 AM
NetsToy
Joined Jul 5, '14
Now you're talkin'! I can see myself cruising around in a little MR2 convertible. smile.gif
4 Pages V  « < 2 3 4
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 22nd, 2024 - 12:32 AM
