Enthusiast ![]() Joined Mar 4, '18 From Oregon Currently Offline Reputation: 0 (0%) ![]() |
So before redo my timing on my Celica wanted to ask you guys that have the 5sfe engine do you or have you ran into the issue where the oil light comes one or flickers at idle (since it started will turn off under acceleration). Also the idle is a bit lower than normal.
For some backup story is swap engine got it for what it seemed to be running good but later on found it was burning oil the oil light turns on only at idle but oil was low (none on dipstick). put more oil and replaced cam seal redid timing and put it to 10 degrees for it was at 9 degrees. Oil light comes on only when the vehicle is warm, not cold. any suggestion thank you thinking of two things redoing timing and oil pressure relief valve is stuck open |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) ![]() |
have you checked for leaks? Is the engine caked in oil? Does the car smoke out of the exhaust (idle, cold start, and/or driving)?
you might have a vacuum leak causing the low idle. It should hover at about 750RPM. -------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Check the oil pressure when cold and as it warms up, general rule of thumb you want 10 psi for every 1,000 rpm. Oil pump could be going out or weak.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
check the wire, could be ready to break off
Enthusiast ![]() Joined Jan 27, '14 From Houston Currently Offline Reputation: 0 (0%) ![]() |
My oil light came on it when the wire broke off.
The sensor I believe is a knock sensor And is located on the right side of the valve cover. If it’s not damage then you might have weak oil pressure |
So i order a oil pump assembly never replace it when the engine was out dumb mistake
@Box my oil light would only turn on when hot even after replacing oil sending unit and checking oil also my idle would drop. So waiting for the part to come in and took off all vacuum hose to clean them for now will replace them in future Want to make sure my evap and egr system are good as well as eliminating any problem with low oil pressure. After that recheck my timing. Will check my wires at connector |
Lo-Fi Version | Time is now: February 16th, 2025 - 2:38 PM |
