7afe Help, Car running poorly when it gets to operating temp |
Oct 15, 2018 - 12:14 PM |
Enthusiast Joined Jan 26, '15 From McDonough Georgia Currently Offline Reputation: 0 (0%) |
I have a 94 st with the 7afe engine, it had a problem that it died amd would not crank or turn over
I had the distributor replaced and now it starts and runs The problem is that now when it gets to operating temperature, it looses lots of power and will not accelerate past 2krpm Any idea what it could be? I would like to fix it myself because I am a bit tight on money at the moment The shop said it could be a clogged cat converter, so I disconnected it and it would still not go past 2krpm when at operating temperature |
Oct 15, 2018 - 1:40 PM |
Enthusiast Joined Jul 26, '12 From Atlanta Currently Offline Reputation: 0 (0%) |
Did you check the spark timing?
Oct 15, 2018 - 2:54 PM |
So it's completely fine up to operating temperature? It was also completely fine at all times before the distributor died? If all that is so, I'd lean towards the distributor being out of time. On these you have to put the car into a special mode before setting the timing by jumping TE1 and E1 terminals in the diagnostic port, otherwise the computer will reset the timing where it thinks it should be.
Oct 15, 2018 - 3:09 PM |
It was running well up until the distributor died
The shop that replaced it said that they checked the timing after replacing it When i start it up cold, it will run perfectly fine up until it gets to operating temperature |
Oct 15, 2018 - 3:58 PM |
Oct 15, 2018 - 9:49 PM |
The aftermarket distributors are plagued with problems when they're hot, most fail in some way or another. https://www.toyotanation.com/forum/130-coro...ult-issues.html
Lo-Fi Version | Time is now: November 23rd, 2024 - 7:34 AM |
