97 gt fog lights don’t work |
Oct 29, 2018 - 8:59 PM |
Enthusiast Joined Oct 29, '18 From Jersey Currently Offline Reputation: 0 (0%) |
Any advice on where to start? I check fuse and tried different fuse. No go. When I turn the switch on the stalk I hear a click, it n lights. I changed both bulbs, no go. I don’t know what else to do to get these fog lights to work. I could use them too! Any suggestions?!?
Oct 30, 2018 - 9:33 AM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
Give us a bit more information.
Is your car a 97 GT and did it originally come with fog lights or are you installing these on a celi that didn't come with fogs? you checked the fuse but did u check the relay? here's a write up installing the fogs, it has a reference photo of where the relay is. http://www.6gc.net/forums/index.php?showtopic=38656 -------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Oct 30, 2018 - 11:49 AM |
It's a 97 convertible that I believe had the foglights already installed. I have the foglight switch on the headlight switch like OEM. I checked fuse and when I turn the foglight switch, I hear the "click", which sounds like the relay. I replaced both bulbs.
I also noticed a small button that has the top broken on it under my steering wheel to the left. Looks like small bulb is in a white plastic oval. I can push it in and out. It's in the location of the "second switch" you provided me in the link above. Not sure what it does though. |
Lo-Fi Version | Time is now: November 28th, 2024 - 3:45 AM |
