transmission options |
Dec 20, 2018 - 10:09 PM |
Enthusiast Joined Dec 20, '18 From United States Currently Offline Reputation: 0 (0%) |
does anyone kow what trans missions will go into the celica gt 5sfe engine,only asking due to needing a rebuild.
Dec 21, 2018 - 10:27 AM |
Moderator Joined Jun 29, '08 From Denver Currently Online Reputation: 59 (100%) |
Auto or manual transmission options?
Manual transmission options are S53/S54, E153, E56, and I’m sure there are a few others. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Dec 25, 2018 - 4:44 PM |
its m manual trans that wont allow me to shift to 2,4, and reverse
Dec 26, 2018 - 12:12 PM |
Enthusiast Joined May 30, '16 From wild 100's, South Chicago Currently Offline Reputation: 3 (100%) |
I had that problem and it came out to be the cable
Dec 26, 2018 - 2:37 PM |
I had that problem and it came out to be the cable I agree, it sounds like a cable or bushing issue more than a trans issue. On the driver side of the car, between the engine and firewall, you’ll find where the cables attach to the trans. Be sure to check there, check the cables at the shifter itself, and check to make sure the cables move freely. It could be an issue with the selector on the trans but I would guess it’s more likely to be cables. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Dec 26, 2018 - 9:00 PM |
read my guide in the stickies on removing the engine, it shows the cable and its mounts
Lo-Fi Version | Time is now: November 22nd, 2024 - 7:35 AM |
