Driver side door handle help!!!!! |
Feb 12, 2019 - 11:24 PM |
Enthusiast Joined Jan 27, '14 From Houston Currently Offline Reputation: 0 (0%) |
Ok need help solving this mystery lol.
For some reason when I unlock my driver side door with my key and I pull the handle to open the door It locks it self back up. The only way I can open the door is if i insert the key turn the key to unlock Hold the key in the open position and lift the handle at the same time. What would I have to check or replace ??? |
Feb 13, 2019 - 3:16 AM |
Enthusiast Joined May 17, '14 From Mesa Arizona Currently Offline Reputation: 0 (0%) |
Ok need help solving this mystery lol. For some reason when I unlock my driver side door with my key and I pull the handle to open the door It locks it self back up. The only way I can open the door is if i insert the key turn the key to unlock Hold the key in the open position and lift the handle at the same time. What would I have to check or replace ??? same 2 months ago, never fixed it or diagnosed it but it seems to be working like normal now |
Feb 13, 2019 - 10:37 PM |
Likely you'll need to pull the door latch assembly out of the door, degrease it, and inspect for broken springs inside, if none found then re-grease, reinstall, and test.
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:17 AM |
