> Is my tranny or differential broke?
post Apr 24, 2019 - 10:45 PM
HardHead93
Joined Apr 7, '15
From New Mexico
The car has been leaking gear oil. I thought it was an axle seal so I took it to my local shop because they installed the original seal and would warranty it. Come to find out it is not the seal. The axle has some serious in and out play in it. When it moves out gear oil leaks out. The shop has tried 2 other brand new axles and the problem is the same. The last axle would not click and lock in. I have a helical LSD in an S54 transmission and I am running a Gen 4 3sgte tuned for 340 hp on E85. I track the car so it gets beat on pretty hard. The shop is having a hard time getting a good part number because the original part number is discontinued but superseded by another. One axle came from OReilly's and the other came from AutoZone. Is the tranny or the differential broke or am I not getting the right axle? Has anyone else had this problem?
post Apr 25, 2019 - 1:40 PM
slavie
Joined May 2, '15
From NY
Can you quantify "serious in and out play"? Also, I'm assuming we're talking driver's side axle since you mentioned the snap ring which is not present in the pas side axle.
Some in and out play is normal as there's some slop in the snap ring securing mechanism. Maybe about 1/8 of an inch.
With aftermarket axles, you MUST install a new seal with a new axle. OEM seal is much preferred - I've had aftermarket seals leak within weeks of installation. As you may have heard, quality control on aftermarket garbage is non-existent, and sometimes the shaft is slightly undersized. A new seal will wear to the shaft, if you will, and seal. If you then take a new, random-sized shaft, and the old seal that was previously working on a different sized shaft, you get a pretty massive oil leak - you'd be surprised just how much oil can leak past. We're talking puddles, not just stains under the car. Ask me how I know.
The fact that a third axle would not even snap in does not surprise me either. I've had aftermarket axles where the snap ring it would seem was bent out of some standard wire not treated in any way with no spring to it, and that garbage will deform and not go in when you try to insert it. I've had to remove original springy snap rings and put them onto brand new aftermarket axles.
TL;DR: Aftermarket garbage is the root of all evil and belongs in the garbage.
post Apr 25, 2019 - 2:37 PM
Box
Joined Feb 23, '12
From Warrior, AL
^That. My brother had issues with his Maxima and more recently his Audi with CV axles and seals. Honestly I'd find a good used o.e. axle and refurbish it if possible, and use a new o.e. seal. That or use this as an excuse for custom higher strength axles.
2001 Miata LS 5-speed
post Apr 25, 2019 - 7:56 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
I want to say the manual and auto use a different axle and that the length of the part that inserts into the trans is the difference, with one being longer or shorter than the other. I'm assuming it's the driver side because they're the same auto or manual on the right side it seems.
Automatic
https://www.rockauto.com/info/570/TO-8145__ra_p.jpg
Manual
https://www.rockauto.com/info/570/TO-8106__ra_p.jpg
What often happens is that cores aren't sorted/boxed right when they go back for refurb so you'll get parts randomly boxed wrong that way. Might be worth checking inside the diff with a flashlight to make sure nothing has gone wrong, how did the old axle that came out look? Is there excessive up down play in the bushing the axle rides on?
This post has been edited by Bitter: Apr 25, 2019 - 7:59 PM
post Apr 25, 2019 - 9:22 PM
HardHead93
Joined Apr 7, '15
From New Mexico
QUOTE (slavie @ Apr 25, 2019 - 2:40 PM) *
As far as shaft play I would say it is around 1/8 - 1/4" in and out play. The seal does not leak when it is on but leaks a bunch when it is out. I wish I would have taken a picture but yes the snap ring looks like a bent piece of wire. The mechanic was able to widen it with some pliers. The axle never unsnaps just has a lot of play. After all your guys input I think the snap ring is too thin and is cheap garbage.
QUOTE (Bitter @ Apr 25, 2019 - 8:56 PM) *
Automatic
Manual
When I look at your picture of your axle, I see one major difference from mine, it does not have the dust shield over the axle seal. Every OEM picture I see of an axle has that dust shield. I wonder if they went to some cheap replica because like I said earlier, the part number been superseded by a different one.
QUOTE (Box @ Apr 25, 2019 - 3:37 PM) *
I order an OEM seal. What do you mean my custom high strength axles?
post Apr 25, 2019 - 10:56 PM
Box
Joined Feb 23, '12
From Warrior, AL
There're various manufacturers of custom CV axles, there used to be one that everyone here used for when they did 3S-GTE swaps but it's eluding me at the moment. That and I think the E153 swap mandates at least one custom axle. The custom axles can withstand more power without breaking if made to be so, though there's the argument that leaving the axles as the weak link can spare the gearbox and then you just have to replace axles. Generally the axles are made of a chromoly steel and/or thicker than stock, more extreme performance variants even beef up the joints and splines. Though if you're not snapping them you should be fine with stock, just need to get one that's right or maybe just a better snap ring for the one you have.
post Apr 26, 2019 - 11:14 AM
HardHead93
Joined Apr 7, '15
From New Mexico
I just heard back from the mechanic and he had a transmission specialist look at it. He said that there is over 1/2 inch of in and out play. The specialist thinks that there is a problem with the final drive (LSD) that is installed in the tranny. I guess I am getting a used S54 to drop in. Ugh!
post Apr 26, 2019 - 12:59 PM
Box
Joined Feb 23, '12
From Warrior, AL
Sigh, that blows. If it's just the carrier though why a whole other transmission and not just get a new carrier?
post Apr 26, 2019 - 3:29 PM
HardHead93
Joined Apr 7, '15
From New Mexico
QUOTE (Box @ Apr 26, 2019 - 12:59 PM) *
What do you mean by carrier? Isn’t everything that the axle snaps into, inside the transmission?
post Apr 26, 2019 - 6:09 PM
Bitter
Joined Mar 11, '06
QUOTE (HardHead93 @ Apr 26, 2019 - 3:29 PM) *
It is but they're all parts inside, as long as the case halves aren't boned you can split it and fix it usually.
post Apr 26, 2019 - 7:28 PM
HardHead93
Joined Apr 7, '15
From New Mexico
QUOTE (Bitter @ Apr 26, 2019 - 6:09 PM) *
True, the problem is that I took it to my mechanic to give it a once over so I could sell this car. I was expecting it to only be an axle seal. Not this issue. I scored a transmission out of a 93 Toyota Camry (S51) for $200. So I plan to swap that in next weekend.
This post has been edited by HardHead93: Apr 26, 2019 - 7:29 PM
post Apr 26, 2019 - 7:32 PM
Box
Joined Feb 23, '12
From Warrior, AL
The carrier is what the ring gear attaches to and is the bulk of what makes up the differential.
post Apr 26, 2019 - 11:41 PM
slavie
Joined May 2, '15
From NY
Keep in mind that the Camry box has different (taller) gears and final drive. The car will accelerate a tad slower, and your highway RPM will be lower.
If you're committed to replacing the gearbox, I may be interested in your old one with the LSD. If the price is right, I'll take a chance at repairing it. Let me know...
post Apr 27, 2019 - 9:49 AM
HardHead93
Joined Apr 7, '15
From New Mexico
QUOTE (slavie @ Apr 27, 2019 - 12:41 AM) *
I will think about it. I was planning to include the tranny as a spare with the car when I sell it. I will be swapping the transmissions next weekend. I am trying to not be the idiot who wants good money for his car but it is broken. As far as the longer gearing, I wish I would have looked into this sooner. The s54 has me shifting through the first 3 gears a lot plus revs close to 4000 rpm in 5th gear on the freeway.
This post has been edited by HardHead93: Apr 27, 2019 - 11:08 AM
post Apr 29, 2019 - 3:27 PM
HardHead93
Joined Apr 7, '15
From New Mexico
Does the clutch disk from a S54 transmission work in a S51 or S53? I might as well put a new clutch on the car since I am dropping the tranny.
post Apr 29, 2019 - 7:09 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (HardHead93 @ Apr 29, 2019 - 4:27 PM) *
It should work just fine
post Apr 30, 2019 - 12:10 AM
slavie
Joined May 2, '15
From NY
The gearboxes are identical aside from the gear ratios inside.
Also, take a look at the speedo sensor - it may have been cable driven still in 93, so you would have to swap the electronic one from your old gear box. They can be a royal PITA to get out if things are rusty, so be careful. I've broken one or two taking them out back when I was yonder and un-wiser.
post May 2, 2019 - 8:52 PM
HardHead93
Joined Apr 7, '15
From New Mexico
It looks like this tranny has the electronic speed sensor so that is nice. I am not sure if the Camry it came out of was a 93. It could have been a 96. The Camry on the bottom is the one it came out of.
[url=https://flic.kr/p/259TLCp]
Here are the picture of it when I got it home.
[url=https://flic.kr/p/2fLtXL6]
[url=https://flic.kr/p/259TCLH]
Here is a shot after I power washed it and moved it into the garage.
[url=https://flic.kr/p/2fLtXpp]
This was a good deal for $200. I will be swapping it into the Celica tomorrow.
This post has been edited by HardHead93: May 2, 2019 - 8:55 PM
post May 2, 2019 - 8:58 PM
Box
Joined Feb 23, '12
From Warrior, AL
Hard to argue with $200 for a transmission that works.
post May 2, 2019 - 10:03 PM
HardHead93
Joined Apr 7, '15
From New Mexico
I am pretty excited about the gear ratios.
The S54 has the following ratios:
First Gear: 3.285
Second Gear: 1.960
Third Gear: 1.322
Fourth Gear: 1.028
Fifth Gear: 0.820
Reverse Gear: 3.153
Final Drive: 4.176
The S51 has the following ratios:
First Gear: 3.538:1
Second Gear: 1.960:1
Third Gear: 1.250:1
Fourth Gear: 0.945:1
Fifth Gear: 0.731:1
Reverse Gear: 3.153:1
Final Drive: 3.944:1
The S54 at 4000 rpm in 4th gear hits 69 mph while the S51 hits 80 mph. In 5th gear at 3500 rpm the S54 hits 76 mph while the S51 hits 90 mph. This means that the car will not rev high and drone cruising on the highway. Also, the car will have a higher top speed and since it is an aftermarket ECU, there is no governor. The other nice thing about this transmission is the first 2 gears on both transmissions act the same and 3rd gear is a tad bit longer on the S51 so acceleration will not be too affected. The car is riding on 17" x 8" rims with 225/45r17 tires. That makes the tire diameter 25" wide. I used that tire diameter to calculate speed. I used the calculator on this website: http://www.apexgarage.com/tech/gear_ratios.shtml
This post has been edited by HardHead93: May 2, 2019 - 10:04 PM
Lo-Fi Version Time is now: November 22nd, 2024 - 6:56 AM
