> Car stalling when decelerating/tapping on gas pedal
post May 26, 2019 - 5:49 PM
DIZNUTS
Joined May 26, '19
From florida
Hello, I am new to the forum so im sorry if im posting this in the wrong place but i need help with my celica. I recently bought a 99 GT with the 5sfe engine, car needed a good tuneup so i replaced distributor, spark plus/wires, oil, timing belt, and a few hoses that looked old. Car runs way better now but im having a problem that i cant figure out whats causing it. The car idles low when in drive and feels a little shaky, almost like is choking or something but the real problem happens when i tap the pedal from a stop, the rpm goes up a little but as soon as i let off the gas, the rpm drops to the point where sometimes it'll stall. it only happens when i tap or give it little gas, like if im at a traffic jam and the car in front of me moves a little and i hit the gas slightly. otherwise it doesnt stall. i already cleaned the IAC valve and throttle body. The only code im getting right now is a p0446 evap code but i've been told that wouldnt cause my car to stall. im thinking i might've messed up the timing belt job or maybe the ecu is bad?
what do you guys recommend i check? P.S (English is my second language so sorry if i made mistakes.)
post May 26, 2019 - 6:49 PM
Box
Joined Feb 23, '12
From Warrior, AL
Welcome! I'm guessing your car is an automatic since you mention putting it into drive? Was this problem present before doing the timing job? If it wasn't I'd look at the timing and make sure things like the cam and crank sensor have clean contacts and are snug.
Also, if it's any consolation your English is better than most primary English speakers.
2001 Miata LS 5-speed
post May 26, 2019 - 7:27 PM
DIZNUTS
Joined May 26, '19
From florida
QUOTE (Box @ May 26, 2019 - 12:49 PM) *
Yes, the problem was present before the timing belt job but the reason i replaced it was because it was worn out and a little loose so maybe it had already jumped a few teeth as it was running pretty bad and was giving me a crankshaft position sensor code. Now, after replacing the belt, the car runs way better but still dies on me sometimes after giving the throttle a blip. also, the RPM drops very low when idling so i have to put the car on neutral while at a stop to prevent it from dying on me. I would also like to say that it was my first time replacing the timing belt so it's a possibility that i messed something up in there.
I was quoted $80 just for a diagnostic and $446 for replacing the timing belt/waterpump but im trying to make that my last resort. is there anything you think i should have a look at before going that route? Thanks!
post May 26, 2019 - 8:52 PM
Box
Joined Feb 23, '12
From Warrior, AL
I'd double check the timing, as well as making sure the crank and cam sensors are kosher. There's also a test for the IACV to make sure it's working properly, sometimes just cleaning them isn't enough and odds are that gasket has long perished by now so if that wasn't replaced it could be leaking.
I'd double check the IACV first though as it's easiest.
Lo-Fi Version Time is now: November 26th, 2024 - 10:43 PM
