Enthusiast ![]() Joined Feb 23, '05 From New York Currently Offline Reputation: 0 (0%) ![]() |
Hello All,
Just as the title states, i'm looking for a rim tire combo that will allow me to run a set of slicks on all 4 and the height be enough for the E153 ruining low 9's high 8's. I have been searching around and found a set of 15's that should clear but i still need to know what worked before and whats best for MPH and overall shorter time. Thanks, Eazy |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) ![]() |
So, do you have a swapped FWD, or do you have an ST205?
I'm only asking because the GT-Four has an E154f trans, while many FWD swaps run an E153 for the higher gearing. If you have the ST205 brakes, you might be able to get away with 15s, but I would run 16s, as that's what they came with from the factory This post has been edited by bloodMoney: May 30, 2019 - 12:47 PM -------------------- ~bloodMoney
I need the whole setup from rim tire size and width to tire height and width, mph, 1/4 times.. the car is using a st205 trans
This post has been edited by eazy2001x: Jun 7, 2019 - 4:11 PM |
Lo-Fi Version | Time is now: April 22nd, 2025 - 7:23 PM |
