> Manual shifter linkage popping out
post May 31, 2019 - 1:45 PM
youngestEVer
Joined Jan 18, '19
From Plano, TX
Hello all,
I hope everyone is doing well! I’ve got a 1996 Celica gt convertible, and I’m having an issue with my shifter. I’ll attach a photo of it, but the little plastic ball on the shifter feels very loose as it slides into the white plastic part of the shifter cable. Am I missing a part here? Because it has come off several times now after shifting and I’m not sure what I’m doing wrong.
Thanks for any advise!
post May 31, 2019 - 5:25 PM
cheela
Joined Feb 2, '07
From Berlin, WI
hello there!
check and see if you're missing the little clip that goes on the clip. The ball and linkage slide onto each other pretty easily, it's the clip that holds it and keeps it from falling out. I'm guessing you're missing that or maybe the plastic is worn away and become too big.
post May 31, 2019 - 6:01 PM
youngestEVer
Joined Jan 18, '19
From Plano, TX
QUOTE (cheela @ May 31, 2019 - 6:25 PM) *
hello there!
Thanks so much for the reply!! :-)
Ugh...having trouble figuring out how to attach a picture!
Try using this link.. https://ibb.co/f2whBsy for the picture. Yours looks so much nicer and made of metal! Yeah mine has no clips, but I also see that yours has more of the "ridges" to hold the clips than mine does. What do y'all recommend I do?
Thanks!
post May 31, 2019 - 7:29 PM
Box
Joined Feb 23, '12
From Warrior, AL
Well, could try finding the retainer and bushing cup off a car in a junk yard. Until then you might try packing the bushing cup with some grease to see if that helps temporarily.
2001 Miata LS 5-speed
post Jun 2, 2019 - 10:44 AM
cheela
Joined Feb 2, '07
From Berlin, WI
a metal wire twisted around there might even hold up for a while until you find the retainer clip.
Lo-Fi Version Time is now: February 17th, 2025 - 2:07 AM
