> Retracting Rear Brake Piston
post Aug 29, 2019 - 10:20 AM
Mr_Man
Joined Dec 13, '16
From Bristol, UK
Howdy.
Just a quick question about resetting the brake piston on the rears. I have a 1996 ST202 3SGE.
Do our pistons rotate as they retract, or do they just move straight back? Also, if they do rotate, which direction?
Just need to figure out my best course of action if the piston happens to be seized.
Cheers!
post Aug 29, 2019 - 11:57 AM
richee3
Joined Jun 29, '08
From Denver
They simply push back in, no rotation necessary. Sounds like you may have a seized caliper if it isn’t pushing back in.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 2, 2019 - 7:54 AM
Mr_Man
Joined Dec 13, '16
From Bristol, UK
QUOTE (richee3 @ Aug 29, 2019 - 12:57 PM) *
Thanks.
Yeah, plus the bleeder valves won't budge either. Both sides. My own fault for not bleeding the brakes sooner.
I had the caliper off, pushed the brake pedal in and you could see the brake line moving, but the piston was going nowhere.
Ordered two replacement calipers and a rebuild kit.
Might see if I can plast the seized pistons to the moon with a foot pump or grease gun once I have the old calipers out.
post Sep 4, 2019 - 7:24 AM
narly_charley
Joined Sep 1, '09
From Marengo, IL
Welcome to my world. I seem to be the most unlucky person in the world when it comes to brakes. I've owned a handful of vehicles in the little time that I've had my license and I've had to replace at least one caliper on every vehicle.
2000 GT-S 6 SPD... SOLD!
Lo-Fi Version Time is now: November 30th, 2024 - 5:50 AM
