1995 Toyota Celica Automatic Transmission not engaging, Transmission help |
Oct 20, 2019 - 2:06 PM |
Enthusiast Joined Oct 17, '19 Currently Offline Reputation: 0 (0%) |
Hi everyone,
I have a 1995 Toyota Celica GT with the 5SFE engine and A140E automatic transmission. The engine runs completely fine, but I’m unable to engage the transmission at all. Basically any gear I shift into (Reverse, Drive, 2, Low) the car acts like it’s in neutral. Here’s a link to a video I made while the car was in Drive: https://youtu.be/8qGcj6dqRXc There’s a knocking sound you can hear as well as a harsh grinding sound when I put the shifter to Park near the end of the video. If anyone has any idea of what this problem might be, please leave a comment. I’ll likely have to replace a part in the transmission (or the entire transmission) to get this thing running again. Don’t hesitate to ask questions as well. Thanks! |
Oct 20, 2019 - 10:04 PM |
Does it have sufficient fluid level? Is the shifter cable still attached at both ends?
Oct 21, 2019 - 12:26 PM |
Does it have sufficient fluid level? Is the shifter cable still attached at both ends? I changed the fluid (even pushed out the fluid from the torque converter) and the car will still act like it’s in neutral no matter what gear I’m in. Where is the shifter cable located on each end? Is there a document/procedure I can reference? Thanks! |
Lo-Fi Version | Time is now: November 23rd, 2024 - 5:47 AM |
