> Hot Stalling problem SOLVED 2.2 liter 5S-FE Bad Caps in ECU, stalling at stop lights, stalling after warmup
post Sep 14, 2020 - 9:36 AM
71Bacon
Joined Sep 14, '20
From 95Celica
Hello out there in ancient Toyota-land,
So, I've spent 6 months or so chasing an idling / stalling problem with my 1995 Celica GT, US domestic market 2.2 liter 5S-FE
The symptoms were the car would stall when warmed up and then would not restart until after it had cooled off. I checked it and it had absolutely no spark at all. Following the diagnosis procedure in the factory maintenance manual led to either "bad wiring harness" or "Bad ECU". In addition a repair shop and even the dealer took a crack at it and the only error the dealer could come up with was "faulty signal from distributor" or something like that. The ECU was showing no codes and no check engine light.
The Internet of things says this hot stalling on a 2.2 is primarily caused by:
- Bad ignitor
- Cracked coil in the distributor
- Bad ECT Engine Coolant Temp Sensor
Chasing this problem and others, I had replaced all of those, and in addition
- Plugs
- Wires
- EGR valve
- EGR proportioning valve
What I found is my rough / low idle was caused by a dirty Idle Air Valve. I took this off and cleaned it with throttle body cleaner like is posted everywhere on the Internet.
After I took the ECU apart I found a blow 147pf capacitor, it had **** the bed. So using a capacitor replacement kit from Ebay "1990-2002 Toyota / Lexus ECU/ECM/Computer Capacitor Kit (MR2, Camry, LS400, etc)
Listed for charity.1990-2002 Toyota / Lexus ECU/ECM/Computer Capacitor Kit (MR2, Camry, LS400, etc)" from the seller "blenddoor" (no affiliation).
I replaced all of the capacitors in the ECU and that fixed it!! No more hot stall, car starts and idles like new, can restart when hot over and over with no issues.
Heres the ECU
And here's a shot of the capacitor that **** the bed. The top didn't bulge, instead it leaked out the bottom. The leakage is the brown pile underneath it.
Hope that helps somebody, it was a long journey for myself and even the dealer.
post Sep 14, 2020 - 10:10 AM
good to hear!
for future refrence there is a company called relentless motorsports out of TX that can complete this service for people that dont feel comfortable replacing the caps themselves.
post Sep 14, 2020 - 10:06 PM
QUOTE (presure2 @ Sep 14, 2020 - 10:10 AM) *
good to hear!
any ecu? I have a 1jz that sometimes has a hard start, and that has rough idle, not all the time, need to check that ecu
post Sep 14, 2020 - 10:32 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (njccmd2002 @ Sep 14, 2020 - 9:06 PM) *
If they don’t, Drift Motion in St. Louis will do the 1JZ ECU for sure.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 14, 2020 - 10:36 PM
QUOTE (richee3 @ Sep 14, 2020 - 10:32 PM) *
ill have to take it apart and examine. thx
This post has been edited by njccmd2002: Sep 14, 2020 - 10:36 PM
post Sep 14, 2020 - 11:18 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
This has cropped up with a problem Corolla over at Toyotanation as well that had an intermittent no start and odd engine light operation. It's been a known issue with gauge clusters failing on 7th gen Corolla for a number of years, but I guess the ECU's are aging into this as well. It's a problem best caught early, the chemical slurry inside the caps can eat board traces which is a big problem potentially. You have to be pretty handy to fix that level of broken.
post Sep 15, 2020 - 7:00 AM
navseal345
Joined Aug 17, '09
From Millard, Omaha, Nebraska
Currently Online
Now this is a good/ interesting post. Thanks for sharing.
post Sep 15, 2020 - 12:47 PM
holly moly its 700+ dollars at drift motion
https://www.driftmotion.com/1JZ-ECU-Cap-Service-p/dm1251.htm
post Sep 15, 2020 - 1:04 PM
im going to call this guy
https://www.youtube.com/watch?v=VC4f6XlEyMA
post Sep 17, 2020 - 6:38 AM
QUOTE (njccmd2002 @ Sep 14, 2020 - 11:06 PM) *
good to hear!
yes.
Lo-Fi Version Time is now: February 16th, 2025 - 4:52 PM
