GT/ST Exhaust Compatibility |
Oct 23, 2020 - 12:18 PM |
Enthusiast Joined Mar 29, '19 Currently Offline Reputation: 0 (0%) |
Hi I've got an 99 SR model and the backbox is rusted to the point it is leaking. I'm wondering if I'm able to replace the backbox with a GT model backbox with it being able to just bolt straight up to the existing stock exhaust without modifications?
From what I can see they look almost identical but the GT exhaust looks a bit nicer Here are two listings on Ebay: GT: www.ebay.co.uk/itm/264395903883?ul_noapp=true ST: www.ebay.co.uk/itm/254723597905 If so, will this hold true for aftermarket parts as well? Thanks for any help. |
Oct 24, 2020 - 12:12 AM |
im not sure. best would be to check toyota diagrams, but even then thats not a for sure thing as pipe diameter will be different
Oct 26, 2020 - 12:51 PM |
im not sure. best would be to check toyota diagrams, but even then thats not a for sure thing as pipe diameter will be different The pipe diameters are the same aren't they? I think as a whole exhaust system it's easily interchangeable but as for individual parts bolting onto another system I'm not sure but I don't see why it wouldn't. |
Oct 28, 2020 - 7:07 AM |
Enthusiast Joined May 2, '15 From NY Currently Offline Reputation: 3 (100%) |
Chances are good that your flanges are rusted to oblivion as well, so nothing will "bolt on" because your flanges will turn to dust when you remove the existing muffler. I just had to go through this on my 96 GT - all the flanges were rusted and farting. I had to grind off old flanges and weld on new Walker brand universal flanges.
Toyota used what looks like stainless piping and even stainless welding wire on their exhausts from this era, but inexplicably installed mild steel flanges that rust away in time. |
Oct 28, 2020 - 9:35 AM |
Diameter is a different size between the 7A-FE and 5S-FE/3S.
Lo-Fi Version | Time is now: November 30th, 2024 - 3:53 PM |
