3SGE Beams ITB |
3SGE Beams ITB |
Nov 28, 2020 - 2:31 PM |
Enthusiast Joined Jul 30, '20 From Vermont USA Currently Offline Reputation: 0 (0%) |
hey all, i was wondering whats the easiest way to run ITB's on a redtop/blacktop beams for my celica.
any ecu modifications or harness changes ill have to make? im not worried about finding ones that will fit cause i can make adapters, but if anybody knows of the itbs themselves ill need that will be helpful too. and to anybody thats done this, is there a significant power increase at all? (im mostly after the sound and cool factor lol) thanks for anhy help! |
Nov 29, 2020 - 4:12 PM |
you can find adapters easily and then use 20V blacktop ITBs. Youd probably need some short velocity stacks so you can clear the firewall
You'd need to run a standalone. You won't see a significant power increase. Youll have a bit snappier throttle response -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Nov 30, 2020 - 1:40 AM |
you can find adapters easily and then use 20V blacktop ITBs. Youd probably need some short velocity stacks so you can clear the firewall You'd need to run a standalone. You won't see a significant power increase. Youll have a bit snappier throttle response where can i find a standalone for a single vvti blacktop beams? |
Dec 1, 2020 - 1:31 AM |
itb are mainly used to smooth out idle on very aggressive upgraded cams. so larger header, intake n exhaust cams with itb and standalone would be great. your thinking if 4age blacktop in stock form has them why not the redtop beams.
you want sound. make a short ram intake with the filter insulated in a box to keep out heat. This post has been edited by BonzaiCelica: Oct 28, 2024 - 1:47 PM -------------------- Group buy to replicate Narrow E series transaxle parts
Dec 2, 2020 - 8:43 PM |
itb are mainly used to smoooth out idle of very agressive upgraded cams. so larger header, intake n exhaust cams with itb with standalone would be great. your thinking if 4age blacktop in stock form has them why not the redtop beams. you want sound. make a short ram intake with the filter insulated in a box to keep out heat. well id love cams too, do you know where i can get redtop cams or standalone? |
Lo-Fi Version | Time is now: November 22nd, 2024 - 11:56 AM |
